Charge and sync your USB 2.0 Micro-B devices from a USB-C host, over longer distances. This USB-C to Micro-B cable lets you charge and sync a USB 2.0 Micro-USB mobile device from a USB Type-C laptop. You can also charge your device using a USB-C wall charger, car charger or power bank, or connect an external Micro-USB drive for easy data backups.
The 2-meter cable gives you the length you need to overcome distance restrictions and stay connected. You can charge and sync your Micro-USB mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, the connection to your mobile device will reach your computer or wall charger more comfortably.
You can also use the USB-C to Micro-USB cable to back up data to an external Micro-USB 2.0 drive from your USB-C or Thunderbolt 3 computer.
The longer cable lets you organize your desk to match your needs, enabling you to connect your device up to 2-meters away from your computer.
Reliable connectivity
This cable features shielded technology that minimizes signal interference, providing a stable connection for charging and data transfer tasks. -
Versatile compatibility
The USB-C to Micro-USB design allows this cable to connect a variety of devices, accommodating modern smartphones, tablets, and USB peripherals. -
Durable construction
Built with a PVC jacket and aluminum mylar foil shielding, this cable is designed to withstand everyday use while maintaining performance.
- StarTech.com USB C to Micro USB Cable 2m 6ft - USB-C to Micro USB Charge Cable - USB 2.0 Type C to Micro B - Thunderbolt 3 Compatible (USB2CUB2M) - USB-C cable - 24 pin USB-C to Micro-USB Type B - 2 m
- USB-C cable
- Technology
- Shielded
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Length
- 2 m
- Black
- 58 g
- Connector
- USB / USB 2.0, RoHS, WEEE
StarTech.com 1m USB 2.0 C to Micro-USB Cable | In Stock | £8.11 |
StarTech.com 2m USB 2.0 C to Micro B Cable | In Stock | £11.32 |
StarTech.com 0.5m USB 2.0 C Micro-B Cable | In Stock | £8.08 |
