StarTech.com 2m USB 2.0 A to Right Angle B Cable - M/M
Quicklinx: 93WWWS00 Mfr#: USBAB2MR
Length: 2m
14 In Stock
£5.42 ex VAT
£6.50 inc VAT
Connect hard-to-reach USB 2.0 peripherals, for installation in narrow spaces. The USBAB2MR 2-meter USB printer cable features one USB 'A' male connector and one right-angle USB 'B' male connector, providing a high-quality connection to USB 2.0 peripherals.
The right-angled USB 'B' connector allows you to connect to your hard-to-reach USB 2.0 printers, scanners, external hard drives, etc. and enables installation in narrow spaces.
As an alternative, StarTech.com also offers a2mUSB 2.0 A to Left Angle B Cable(USBAB2ML), which provides the same convenience as this right-angled cable, but allows you to connect to your USB device from the opposite direction.
  • Flexible Installation
    The right-angle USB connector allows for easy connections in tight spaces, providing flexibility and convenience for setup.
  • Durable Construction
    Nickel plating on connectors enhances durability and helps prevent corrosion, ensuring a long-lasting connection.
  • Reliable Data Transfer
    Double shielded technology minimizes signal interference, facilitating consistent data transfer speeds for printing and other applications.
StarTech.com 2m USB 2.0 A to Right Angle B Cable Cord - 2 m USB Printer Cable - Right Angle USB B Cable - 1x USB A (M), 1x USB B (M) (USBAB2MR) - USB cable - USB Type B to USB - 2 m
USB cable
Double shielded
90° connector
Length
2 m
Connector
4 pin USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
USB cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
90° connector
Length
2 m
Connector
USB / USB 2.0, RoHS
93WW StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £20.17
93WW StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M In Stock £33.33
93WW StarTech.com 1m USB 2.0 A to Right Angle B Cable - M/M In Stock £5.59
93WW StarTech.com 3M RIGHT ANGLE USB PRINTER In Stock £5.82
93WW StarTech.com 2m USB 2.0 A to Right Angle B Cable - M/M In Stock £5.42
Length: 2m
