Connect hard-to-reach USB 2.0 peripherals, for installation in narrow spaces. The USBAB2ML 2-meter USB printer cable features one USB-A male connector and one left-angle USB-B male connector, providing a high-quality connection to USB 2.0 peripherals and enabling installation in narrow spaces.
As an alternative, StarTech.com also offers a 2m USB 2.0 A to Right Angle B Cable (USBAB2MR), which provides the same convenience as this left-angled cable, but allows you to connect to your USB device from the opposite direction.
                Versatile connector designThe left angle connector of this USB cable allows for easy connections in tight spaces, making it suitable for various setups and environments.
                Reliable data transfer capacityDesigned to comply with USB 2.0 standards, this cable ensures efficient data transfer rates, supporting a range of devices with ease.
                Durable and efficient constructionBuilt with a shielded design and nickel-plated connectors, this cable promotes durability and reduces interference for consistent connectivity.
                Flexibility and compatibilityWith a 24/28 American Wire Gauge, this cable offers the flexibility needed for a variety of applications while maintaining compatibility with numerous devices.
- StarTech.com 2m USB 2.0 A to Left Angle B Cable Cord - 2 m USB Printer Cable - Left Angle USB B Cable - 1x USB A (M), 1x USB B (M) (USBAB2ML) - USB cable - USB Type B to USB - 2 m
- USB cable
- Technology
- Shielded
- Left-angled connector
- Length
- 2 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Length
- 2 m
- Black
- Connector
- USB / USB 2.0, RoHS
|  | StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M | In Stock | £19.36 |
|  | StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M | In Stock | £32.53 |
|  | StarTech.com 1m USB 2.0 A to Right Angle B Cable - M/M | In Stock | £5.19 |
|  | StarTech.com 3M RIGHT ANGLE USB PRINTER | In Stock | £5.61 |
|  | StarTech.com 2m USB 2.0 A to Right Angle B Cable - M/M | In Stock | £5.10 |
|  | StarTech.com 2m USB 2.0 A to Left Angle B Cable - M/M | In Stock | £5.14 |
|  | StarTech.com 1m USB 2.0 A to Left Angle B Cable - M/M | In Stock | £4.89 |
|  | StarTech.com 3m USB 2.0 A to Left Angle B Cable - M/M | In Stock | £5.31 |
