The USB2HAB2M 2-meter USB A-to-B cable features one USB ''A'' male connector and one USB ''B'' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives.
Reliable Connectivity
This USB 2.0 cable offers stable connections for devices like printers and scanners, ensuring efficient data transfer. -
Durable Construction
Featuring a 24/28 AWG design, the cable withstands everyday use while maintaining performance integrity. -
Easy to Use
With male connectors on both ends, the cable simplifies installations and replacements, enhancing user experience. -
Environmentally Compliant
The cable meets RoHS standards, indicating its low impact on the environment and safety for users. -
Versatile Length
At 2 m long, this cable provides the flexibility needed for various setups, accommodating different spaces.
- StarTech.com 2m USB 2.0 A to B Cable M/M - USB cable - USB to USB Type B - 2 m
- USB cable
- Length
- 2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- American Wire Gauge (AWG)
- 24/28
- Length
- 2 m
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 1m USB 2.0 A to B Cable - M/M | In Stock | £3.71 |
StarTech.com 2m USB 2.0 A to B Cable - M/M | In Stock | £3.84 |
StarTech.com 3m USB 2.0 A to B Cable - M/M | In Stock | £4.51 |
StarTech.com 0.5m USB 2.0 A to B Cable - M/M | In Stock | £3.13 |
StarTech.com 5m USB 2.0 A to B Cable - M/M | In Stock | £5.75 |
