Connect four MSA compliant 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This QSFP+ breakout cable connects a single QSFP+ port to four 10G SFP+ ports and delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies. It supports short-distance applications, such as point-to-point in-rack network switch or server connections, for up to four 10G SFP+ devices.
- StarTech.com MSA Uncoded Compatible 2m 40G QSFP+ to 4x SFP+ Direct Attach Breakout Cable Twinax, 40GbE QSFP+ to 4x SFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC Cable - Lifetime Warranty (QSFP4SFPPC2M) - breakout cable - 2 m - black
- Breakout cable - SFF-8431/SFF-8432/SFF-8436
- Technology
- Twinaxial
- Passive cable
- Length
- 2 m
- Connector
- QSFP+ - latched
- Connector (Second End)
- 4 x SFP+ - latched
- Black
- 2-year warranty
- Network Cable Type
- Technology
- Twinaxial
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 30
- Impedance
- 100 Ohm
- Passive cable
- Length
- 2 m
- 100 g
- Black
- Connector
- QSFP+ - latched
- FCC, RoHS, MSA
- 2-year warranty
- 0 °C
- 70 °C
