StarTech.com 2m QSFP+ 40-Gigabit Ethernet (40GbE) Passive Copper Twinax Direct Attach Cable
Quicklinx: 9XD9WS00 Mfr#: QSFPMM2M
Connect 40GbE QSFP+ network devices with this high-quality replacement MC2207130-002 cable. The QSFPMM2M 2m QSFP+ cable is a fully hot pluggable, direct attach cable, supporting 56Gb/s Infiniband as well as40 Gigabit Ethernet applications connected through (Quad Small Form Factor Pluggable) QSFP+ ports.
Designed for short length, high speed interconnects, this low power, low latency Twinax cable is a cost-effective alternative to fiber optic cable assemblies and is intended for short distance applications such as point-to-point in-rack and across rack network switch/server connections.
This 4 channel QSFP+ Cable is compliant with MSA (Multi-Source Agreement) standards, making it a reliable replacement MC2207130-002 cable.
StarTech.com MSA Uncoded Compatible 2m 40G QSFP+ to QSFP+ Direct Attach Breakout Cable Twinax, 40 GbE QSFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC, 40GE Breakout Cable - Lifetime Warranty (QSFPMM2M) - direct attach cable - 2 m - black
Direct attach cable
Twinaxial
Latching connectors
Length
2 m
Connector
QSFP+
Connector (Second End)
QSFP+
Network Cable Type
Direct attach cable
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Latching connectors
Length
2 m
Connector
QSFP+
QSFP+
RoHS, MSA
9XD9 StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £36.36
9XD9 StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £40.56
9XD9 StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £46.24
9XD9 StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £60.13
