StarTech.com 2m Premium HDMI Cable - Grips
Quicklinx: CZCVWS00 Mfr#: HDMM2MLP
Length: 2m
£14.48 ex VAT
£17.37 inc VAT
High-retention HDMI connections that are certified to provide premium, error-free performance. This 2-meter HDMI cable has been tested in accordance with the Premium HDMI Cable Certification Program. This ensures it's able to deliver the newest technical features that the latest HDMI specifications have to offer, including enhanced resolutions and protection against EMI interference.
The cable features high-retention HDMI connectors that fasten firmly inside each port. This helps to prevent accidental disconnections and signal loss.
Each cable is labeled with the Premium HDMI Cable authentication, so you can be confident that you are purchasing a high-quality premium cable with guaranteed performance.
The cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors.
With higher resolutions, increased speeds, and sharper images, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI capabilities available today. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage.
Plus, the cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices.
The gripping HDMI connectors are ideal for high traffic applications or in environments where vibrations could cause accidental disconnects and picture loss. It works great with wall-mounted equipment and in situations where equipment is frequently moved.
Plug the connectors inside the HDMI ports and the connectors will automatically latch to the inside of the port, there are no special screws or accessories required. The grips will create contact pressure inside the port and ensure that the connectors don't loosen over time.
The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center to ensure it supports the high-bandwidth enabled features it promises. An EMI test is also performed to ensure the cable minimizes interference with wireless signals.
  • Experience the latest that HDMI has to offer
    The cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors. With higher resolutions, increased speeds, and sharper images, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI capabilities available today. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage. Plus, the cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices.
  • Secure your connections and avoid signal loss
    The gripping HDMI connectors are ideal for high traffic applications or in environments where vibrations could cause accidental disconnects and picture loss. It works great with wall-mounted equipment and in situations where equipment is frequently moved. Plug the connectors inside the HDMI ports and the connectors will automatically latch to the inside of the port, there are no special screws or accessories required. The grips will create contact pressure inside the port and ensure that the connectors don't loosen over time.
  • Provide superior connections with Premium HDMI certification
    The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center to ensure it supports the high-bandwidth enabled features it promises. An EMI test is also performed to ensure the cable minimizes interference with wireless signals. The HDMM2MLP is backed by StarTech.com's Lifetime Warranty.
StarTech.com 6.6ft (2m) HDMI 2.0 Cable, 4K Premium Certified High Speed HDMI Cable with Ethernet, 4K 60Hz HDR10, Ultra HD HDMI Cable, Long HDMI Cable/Cord for TV/Monitor/Laptop/PC - HDMI to HDMI Video Cable - M/M - HDMI cable - 2 m
Cable
HDMI cable
American Wire Gauge (AWG)
34
Length
2 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K format support, HDR support, gripping connectors
P/N: ST122HD202, ST124HD202, TB32HD24K60, TB3DKM2HDL
Cable Type
HDMI cable
34
Jacket Material
PVC
Length
2 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS, WEEE, CEC, EMI
125 g
Limited warranty - lifetime
CZCV StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.35
CZCV StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.89
CZCV StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £19.66
CZCV StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip In Stock £10.66
Length: 2m
