StarTech.com 2m Power Cord Schuko CEE7 to 2x C13 - EU
Quicklinx: DPTGWS00 Mfr#: PXT101YEU2M
Type: Power
Select:
£8.53 ex VAT
£10.23 inc VAT
Power two devices at once from a single power outlet, perfect for dual-monitor setups. Maximize the outlets on your power strip, surge protector or wall outlet and free up space for other devices. This C13 power cord lets you plug two devices into a single power outlet.
The cord length from the Y-split is 50 cm on each side, giving you an extended reach for securely connecting your devices. You can power two monitors, or a monitor and a computer, or two switches in a rack, without placing strain on the cord.
The C13 power cord is fully tested to ensure maximum performance.
  • Reliable construction
    The power cord is constructed with a durable PVC jacket, ensuring it can withstand daily wear while providing long-lasting service.
  • Flexible connectivity
    Featuring a male power CEE 7/7 connector and an IEC 60320 C13 connector, this power cable offers versatile compatibility with several devices.
StarTech.com 2m (6ft) Computer Power Cord, 18AWG, EU Schuko to 2x C13 Power Cord, 10A 250V, Black Replacement AC Cord, TV/Monitor Power Cable, Schuko CEE 7/7 to IEC 60320 2x C13 Power Cord - PC Power Supply Cable - power cable - power CEE 7/7 to power IEC 60320 C13 - 2 m
Power cable
Length
2 m
Connector
Power CEE 7/7 - male
Connector (Second End)
2 x power IEC 60320 C13
Rated Voltage
AC 250 V
Rated Current
10 A
Power cable
Jacket Material
PVC
Rated Voltage
AC 250 V
Rated Current
10 A
Length
2 m
295 g
Connector
DPTG StarTech.com 6 ft 2 Prong European Power Cord for PC Computers In Stock £5.81
DPTG StarTech.com 2m 3 Prong Laptop Power Cord – Schuko CEE7 to C5 Clover Leaf Power Cable Lead In Stock £6.23
DPTG StarTech.com 1m 3 Prong Laptop Power Cord – Schuko CEE7 to C5 Clover Leaf Power Cable Lead In Stock £5.06
Resources
The following resources are available for the StarTech.com 2m Power Cord Schuko CEE7 to 2x C13 - EU
Type: Power
