Connect fiber network devices for high-speed transfers with LSZH rated cable. The FIBSTSC2 2-meter (6.6ft) Multimode 62.5/125 Duplex Fiber Patch Cable is terminated with one ST (male) connector and one SC (male) connector, to provide the necessary connection between fiber networking devices for high-speed, long distance networks.
This ST-SC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
To ensure optimum performance, the multimode fiber duplex cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
The ST-SC Multimode Fiber Patch cable is guaranteed to provide long-lasting dependability, and top quality performance.
Reliable connectivity
The fiber optic technology ensures a stable connection, allowing for high-speed data transfer across networks without interference. -
Flexible installation
With a length of 2 m, this cable fits various networking environments, offering ease of use.
- StarTech.com 2m Fiber Optic Cable - Multimode Duplex 62.5/125 - LSZH - ST/SC - OM1 - ST to SC Fiber Patch Cable (FIBSTSC2) - network cable - 2 m
- Network cable
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 2 m
- Core / Cladding Diameter
- 62.5 / 125 micron
- Connector
- 2 x SC multi-mode - male
- Connector (Second End)
- 2 x ST multi-mode - male
- Limited lifetime warranty
- Network Cable Type
- Network cable
- Technology
- Multimode
- 62.5 / 125 micron
- Length
- 2 m
- Connector
