Connect fiber network devices for high-speed transfers with LSZH rated cable. The FIBLCLC2 2-meter (6.6ft) Multimode 62.5/125 Duplex Fiber Patch Cable is terminated at both ends with LC (male) connectors, to provide the necessary connection between fiber networking devices for high-speed, long distance networks.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
To ensure optimum performance, the multimode fiber duplex cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
The LC-LC Multimode Fiber Patch cable is guaranteed to provide long-lasting dependability, and top quality performance.
- StarTech.com 2m Fiber Optic Cable - Multimode Duplex 62.5/125 - LSZH - LC/LC - OM1 - LC to LC Fiber Patch Cable (FIBLCLC2) - patch cable - 2 m - orange
- Patch cable
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 2 m
- Core / Cladding Diameter
- 62.5 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Orange
- Network Cable Type
- Patch cable
- Technology
- Multimode
- Fibre Qty
- 2
- 62.5 / 125 micron
- Length
- 2 m
- Orange
- Connector
