Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCST2 2m LSZH LC to ST Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-ST patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
- StarTech.com 2m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/ST - OM2 - LC to ST Fiber Patch Cable - patch cable - 2 m - orange
- Patch cable - OM2
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Molded
- Length
- 2 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x ST multi-mode - male
- Connector (Second End)
- 2 x LC multi-mode - male
- Orange
- Limited lifetime warranty
- Designed For
- P/N: MCM1110MMLC
- Network Cable Type
- Patch cable - OM2
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 50 / 125 micron
- Molded
- Length
- 2 m
- Orange
- Connector
- RoHS
- Designed For
- P/N: MCM1110MMLC
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - ST | In Stock | £11.11 |
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - ST | In Stock | £18.89 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - ST | In Stock | £6.21 |
StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - ST | In Stock | £14.51 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
8M47 042722 Condition: Customer return - item has been used and shows signs of use |
£1.02 |
Ref:
8M47 042723 Condition: Customer return - item has been used and shows signs of use. PLEASE NOTE. Not in original packaging |
£1.02 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
