StarTech.com 2m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets
Quicklinx: 9PS5WS00 Mfr#: USBAUB2MBK
Length: 2m
33 In Stock
£5.47 ex VAT
£6.56 inc VAT
Charge and Sync your Micro USB-equipped Smartphone or Tablet over longer distances. Tired of being attached to the wall when charging and using your phone or tablet?
The USBAUB2MBK Micro USB cable offers 2 meters in cable length so you can charge your device in comfort and from a distance. Plus, the cable offers a slim design that lets you plug into your device without having to take it out of its case for every charge and sync.
Charge your device even while you're taking notes in a boardroom, catching up on emails in a hotel room, or reading in a coffee shop. The 2-meter long charge cable overcomes distance restrictions and lets you stay connected even while charging.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Micro USB connector molding that plugs into your device even while it's inside a protective case.
  • Reliable connectivity
    This cable features a double shielded design that minimizes interference, ensuring consistent data transfer and charging performance.
  • Versatile compatibility
    Designed to work with Mac and other devices, the cable's Micro-USB Type-B and USB Type-A connectors make it suitable for various applications.
  • Durable construction
    Constructed with nickel plated connectors, this cable provides enhanced resistance to wear and tear, extending its lifespan for long-term use.
StarTech.com 2m Mobile Charge Sync USB to Slim Micro USB Cable M/M - USB cable - Micro-USB Type B to USB - 2 m
USB cable
Double shielded
Length
2 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
USB cable
Double shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
2 m
Connector
USB / USB 2.0, RoHS
9PS5 StarTech.com 0.5m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £4.34
9PS5 StarTech.com 2m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £5.47
9PS5 StarTech.com 1m Mobile Charge Sync USB to Slim Micro USB Cable - M/M In Stock £4.74
9PS5 StarTech.com 15cm (6in) Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets In Stock £4.59
9PS5 StarTech.com 3m USB / Slim Micro USB Cable In Stock £5.78
9PS5 StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £13.05
Length: 2m
