Connect your (USB Mini) portable device to a host computer through a standard USB 2.0 type-A slot. The USB2HABM2M 2-meter USB ''A'' to Mini ''B'' Cable provides one (4-pin) USB Type ''A'' male connector and one Mini ''B'' (5-pin) male connector, with support for high-speed USB 2.0 transfer rates up to 480Mbps.
A high quality replacement for connecting your digital camera to a host computer, this durable USB 2.0 cable also delivers a cost-effective way to maximize the file transfer performance of your MP3 player, PDA, or digital camcorder.
Expertly designed and constructed of only top quality materials, the A-to-Mini B USB 2.0 cable offers pure digital data transfers for sharper, more natural images and sound at higher speeds.
Versatile connectivity
This cable features a 4 pin USB Type-A connector on one end and a mini-USB Type-B connector on the other, allowing compatibility with a wide range of devices. -
Reliable data transfer
With a construction of 28 AWG, the cable ensures efficient data transmission, helping you transfer files quickly. -
Durable and shielded design
The cable's shielded technology protects against interference, ensuring smooth connectivity for your devices. -
Environmentally friendly
RoHS compliant, this cable meets safety and environmental standards, making it a responsible choice for consumers.
- StarTech.com 2m Mini USB 2.0 Cable A to Mini B M/M - USB cable - USB to mini-USB Type B - 2 m
- USB cable
- Technology
- Shielded
- Length
- 2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 2 m
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com Mini USB to Micro USB Adapter | In Stock | £3.67 |
StarTech.com 1m Mini USB 2.0 Cable - A to Mini B - M/M | In Stock | £3.71 |
StarTech.com 2m Mini USB 2.0 Cable - A to Mini B - M/M | In Stock | £2.00 |
StarTech.com 3 ft Mini USB Cable - A to Right Angle Mini B | In Stock | £3.32 |
