StarTech.com 2m Mini HDMI to DVI-D Cable - M/M
Quicklinx: 95DPWS00 Mfr#: HDCDVIMM2M
Length: 2m
Hurry, only 3 left in stock!
£11.63 ex VAT
£13.95 inc VAT
View your pictures or videos from your HDMI Mini-equipped camera or other mobile device up to 2m away from your DVI-D display. The HDCDVIMM2M 2m Mini HDMI to DVI-D Cable enables you to view your pictures and videos from your HDMI Mini-equipped camera or other mobile device (Tablet, laptop, etc.) on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 6ft (2m) Slim 3.5mm Stereo Audio Cable (MU6MMS).
The HDCDVIMM2M is designed and constructed for maximum durability, to ensure dependable performance.
  • Durable construction
    The cable features a robust PVC jacket to protect against wear and tear, ensuring longevity in various environments.
  • High-quality connectors
    Equipped with gold-plated connectors, this cable improves signal transmission reliability and reduces the likelihood of corrosion over time.
  • Optimized for video
    Supports video resolutions up to 1920 x 1200, making it suitable for high-definition applications and multimedia setups.
  • Shielded design
    The shielded cable technology reduces electromagnetic interference, resulting in cleaner and clearer video output.
  • Versatile compatibility
    With a 19-pin mini HDMI Type-C connector and an 18+1 pin digital DVI (Single-Link) connector, it works with a variety of devices.
StarTech.com 2m Mini HDMI to DVI-D Cable - M/M - 2 meter Mini HDMI to DVI Cable - 19 pin HDMI (C) Male to DVI-D Male - 1920x1200 Video (HDCDVIMM2M) - adapter cable - HDMI / DVI - 2 m
Cable
Adapter cable - HDMI / DVI
Shielded
American Wire Gauge (AWG)
30
Length
2 m
Connector
DVI-D - male
Connector (Second End)
19 pin mini HDMI Type C - male
Moulded
Cable Type
Adapter cable
Interface Supported
HDMI / DVI
Shielded
30
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Gold
Moulded
Connector
18+1 pin digital DVI (Single-Link) - male
RoHS
Limited warranty - lifetime
95DP StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.62
95DP StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.98
95DP StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
95DP StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £9.40
95DP StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.72
95DP StarTech.com 2m Mini HDMI to DVI-D Cable - M/M In Stock £11.63
95DP StarTech.com 1m Mini HDMI to DVI-D Cable - M/M In Stock £10.55
Length: 2m
