View your pictures or videos from your HDMI Mini-equipped camera or other mobile device up to 2m away from your DVI-D display. The HDCDVIMM2M 2m Mini HDMI to DVI-D Cable enables you to view your pictures and videos from your HDMI Mini-equipped camera or other mobile device (Tablet, laptop, etc.) on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 6ft (2m) Slim 3.5mm Stereo Audio Cable (MU6MMS).
The HDCDVIMM2M is designed and constructed for maximum durability, to ensure dependable performance.
Durable construction
The cable features a robust PVC jacket to protect against wear and tear, ensuring longevity in various environments. -
High-quality connectors
Equipped with gold-plated connectors, this cable improves signal transmission reliability and reduces the likelihood of corrosion over time. -
Optimized for video
Supports video resolutions up to 1920 x 1200, making it suitable for high-definition applications and multimedia setups. -
Shielded design
The shielded cable technology reduces electromagnetic interference, resulting in cleaner and clearer video output. -
Versatile compatibility
With a 19-pin mini HDMI Type-C connector and an 18+1 pin digital DVI (Single-Link) connector, it works with a variety of devices.
 - StarTech.com 2m Mini HDMI to DVI-D Cable - M/M - 2 meter Mini HDMI to DVI Cable - 19 pin HDMI (C) Male to DVI-D Male - 1920x1200 Video (HDCDVIMM2M) - adapter cable - HDMI / DVI - 2 m
- Cable
 - Adapter cable - HDMI / DVI
- Technology
 - Shielded
- American Wire Gauge (AWG)
 - 30
- Length
 - 2 m
 - Black
- Connector
 - DVI-D - male
- Connector (Second End)
 - 19 pin mini HDMI Type C - male
 - Moulded
 - Limited lifetime warranty
- Cable Type
 - Adapter cable
- Interface Supported
 - HDMI / DVI
- Technology
 - Shielded
 - 30
- Jacket Material
 - PVC
- Shielding Material
 - Aluminum mylar foil with braid
- Length
 - 2 m
- Plated Connector
 - Gold
 - Moulded
 - Black
- Connector
 - 18+1 pin digital DVI (Single-Link) - male
 - RoHS
 - Limited warranty - lifetime
                        StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
                        StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.55 |
                        StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
                        StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male | In Stock | £9.05 |
                        StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £9.71 |
                        StarTech.com 2m Mini HDMI to DVI-D Cable - M/M | In Stock | £11.63 |
