View your pictures or videos from your HDMI Micro-equipped Smartphone or other mobile device up to 2m away from your DVI-D display. The HDDDVIMM2M 2m Micro HDMI to DVI-D Cable enables you to view your presentations, videos and pictures saved on your HDMI Micro-equipped mobile devices (Tablet, Smartphone), on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 6ft (2m) Slim 3.5mm Stereo Audio Cable (MU6MMS).
The HDDDVIMM2M is designed and constructed for maximum durability, to ensure dependable performance.
Durable construction
This cable features a molded design with strain relief, ensuring it can withstand the rigors of everyday use. -
High-quality video support
Supports video resolutions up to 1920 x 1200, making it suitable for a wide range of displays. -
Excellent signal integrity
With its shielded technology and gold-plated connectors, this cable maintains excellent signal integrity. -
Flexible usage
The 2 m length allows flexibility in placement, accommodating various setups. -
Safe and compliant materials
Manufactured with RoHS compliant materials, this cable meets environmental safety standards.
- StarTech.com 2m Micro HDMI to DVI-D Cable - M/M - 2 meter Micro HDMI to DVI Cable - 19 pin HDMI (D) Male to DVI-D Male - 1920x1200 Video (HDDDVIMM2M) - adapter cable - HDMI / DVI - 2 m
- Cable
- Adapter cable - HDMI / DVI
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30
- Length
- 2 m
- Black
- Connector
- DVI-D - male
- Connector (Second End)
- 19 pin micro HDMI Type D - male
- Moulded, strain relief
- Limited lifetime warranty
- Cable Type
- Adapter cable
- Interface Supported
- HDMI / DVI
- Technology
- Shielded
- 30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 2 m
- Plated Connector
- Gold
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- RoHS
- Limited warranty - lifetime
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.62 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.98 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.79 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male | In Stock | £9.40 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £9.72 |
StarTech.com 2m Micro HDMI to DVI-D Cable - M/M | In Stock | £11.52 |
StarTech.com 1m Micro HDMI to DVI-D Cable - M/M | In Stock | £3.67 |
