StarTech.com 2m Micro HDMI to DVI-D Cable - M/M
Quicklinx: 95F0WS00 Mfr#: HDDDVIMM2M
Length: 2m
£4.73 ex VAT
£5.67 inc VAT
View your pictures or videos from your HDMI Micro-equipped Smartphone or other mobile device up to 2m away from your DVI-D display. The HDDDVIMM2M 2m Micro HDMI to DVI-D Cable enables you to view your presentations, videos and pictures saved on your HDMI Micro-equipped mobile devices (Tablet, Smartphone), on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 6ft (2m) Slim 3.5mm Stereo Audio Cable (MU6MMS).
The HDDDVIMM2M is designed and constructed for maximum durability, to ensure dependable performance.
  • Durable construction
    This cable features a molded design with strain relief, ensuring it can withstand the rigors of everyday use.
  • High-quality video support
    Supports video resolutions up to 1920 x 1200, making it suitable for a wide range of displays.
  • Excellent signal integrity
    With its shielded technology and gold-plated connectors, this cable maintains excellent signal integrity.
  • Flexible usage
    The 2 m length allows flexibility in placement, accommodating various setups.
  • Safe and compliant materials
    Manufactured with RoHS compliant materials, this cable meets environmental safety standards.
StarTech.com 2m Micro HDMI to DVI-D Cable - M/M - 2 meter Micro HDMI to DVI Cable - 19 pin HDMI (D) Male to DVI-D Male - 1920x1200 Video (HDDDVIMM2M) - adapter cable - HDMI / DVI - 2 m
Cable
Adapter cable - HDMI / DVI
Shielded
American Wire Gauge (AWG)
30
Length
2 m
Connector
DVI-D - male
Connector (Second End)
19 pin micro HDMI Type D - male
Moulded, strain relief
Cable Type
Adapter cable
Interface Supported
HDMI / DVI
Shielded
30
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Gold
Connector
18+1 pin digital DVI (Single-Link) - male
RoHS
Limited warranty - lifetime
95F0 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
95F0 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.48
95F0 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
95F0 StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £9.26
95F0 StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
95F0 StarTech.com 2m Micro HDMI to DVI-D Cable - M/M In Stock £4.73
95F0 StarTech.com 1m Micro HDMI to DVI-D Cable - M/M In Stock £4.26
Length: 2m
