StarTech.com 2m Lightning USB C Micro-B Cable
Quicklinx: F2KNWS00 Mfr#: LTCUB2MGR
Length: 2m
£24.23 ex VAT
£29.07 inc VAT
This USB multi-charging cable is a single-cable solution that makes it easy to charge and sync your Apple Lightning or Android devices.
Keep this USB to Micro-USB, USB-C or Lightning cable on hand for all your charging needs, instead of carrying multiple cables. The 3-in-1 cable makes it easy for you to switch between different device models and platforms. Note that it will only connect to one device at a time.
Charge your devices from a USB wall charger, car charger, or power bank. The longer cable offers a greater range, so you can access your device conveniently even while it's connected to a charger.
With a braided nylon jacket, this durable charging cable doesn't kink or tangle as easily as non-braided cables do. It's an excellent replacement for any of your charging cables.
To charge or sync a USB-C or Lightning mobile device, simply attach the corresponding connector to the Micro-USB connector and plug into your device. To charge or sync a Micro-USB device, plug just the middle connector of the cable into your mobile device.
LTCUB2MGR is Apple MFi certified.
StarTech.com USB Multi Charging Cable - 6.6 ft / 2m - Lightning / USB-C / Micro-USB - Braided - MFi Certified - USB 2.0 - 3 in 1 Charging (LTCUB2MGR) - USB cable kit
USB cable kit
Double shielded
Sync and charge, braided
USB / USB 2.0
Silver
USB cable kit
Double shielded
Shielding Material
American Wire Gauge (AWG)
22/28
Plated Connector
Nickel
Silver
Cable Kit Details
1 x USB cable - 4 pin USB Type A (male) to 5 pin Micro-USB Type B (male) - 2 m , 1 x USB adapter - 5 pin Micro-USB Type B (male) to Apple Lightning connector (male) , 1 x USB adapter - 5 pin Micro-USB Type B (male) to 24 pin USB-C (male)
USB / USB 2.0, MFI
F2KN StarTech.com 1m Lightning USB C Micro-B Cbl In Stock £22.53
Length: 2m
