Connect an HDMI Mini-equipped camera, Smartphone or portable device to your HDMI-capable TV or display. The HDACMM2M HDMI Mini to HDMI Cable with Ethernet lets you connect devices that feature an HDMI Mini port to an HDMI-enabled display/device, providing a cost-saving solution for connecting cutting-edge and next-generation HDMI-enabled devices to existing HDMI technology.
This HDMI Mini to HDMI adapter features high-quality gold-tipped connectors that ensure peak connectivity.
High-quality shielding
The cable features aluminum mylar foil with braid to minimize interference and ensure smooth signal transmission, making it ideal for high-definition content. -
Durable connectors
The 19-pin HDMI Type-A and mini HDMI Type-C connectors are gold-plated, which enhances conductivity and provides corrosion resistance for long-lasting use. -
Enhanced functionality
This HDMI cable includes an HDMI Ethernet Channel (HEC) that allows for network functionality between devices, helping to reduce the number of cables needed. -
Environmentally compliant
Designed to meet RoHS standards, this cable is made with materials that are safe for the environment, supporting eco-friendly practices.
- StarTech.com 2m High Speed HDMI Cable with Ethernet HDMI to HDMI Mini - HDMI cable with Ethernet - 2 m
- Cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30
- Length
- 2 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- 19 pin mini HDMI Type C - male
- HDMI Ethernet Channel (HEC)
- Limited lifetime warranty
- Cable Type
- Technology
- Shielded
- 30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 2 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
StarTech.com 2m High Speed HDMI Cable with Ethernet - HDMI to HDMI Mini- M/M | In Stock | £12.91 |
StarTech.com HDMI Coupler / Gender Changer - F/F | In Stock | £8.59 |
