The HDADMM2M 2-meter High Speed HDMI to HDMI Micro cable enables you to connect devices with an HDMI Micro port to a display/device with a standard HDMI port - a cost-saving solution for connecting cutting-edge and next-generation HDMI-capable devices to existing HDMI technology. The HDMI/HDMI Micro cable features high-quality gold-tipped connectors that ensure peak connectivity.
High compatibility
The cable features a 19-pin HDMI Type-A connector and a male micro HDMI Type D connector, making it compatible with a variety of devices including cameras and tablets. -
Durable construction
With a robust PVC jacket and gold-plated connectors, this HDMI cable is designed to withstand everyday use while ensuring reliable signal transmission. -
Efficient data transfer
The 34 AWG cable design allows for efficient high-speed data transfer, making it ideal for streaming high-definition content and gaming. -
3D support
This cable supports 3D transmission, delivering a rich and engaging visual experience when connected to compatible devices. -
Environmentally friendly
The cable complies with RoHS standards, ensuring it is free from hazardous substances and contributing to sustainable practices.
- StarTech.com 2m High Speed HDMI Cable with Ethernet HDMI to HDMI Micro - HDMI cable with Ethernet - 2 m
- Cable
- American Wire Gauge (AWG)
- 34
- Length
- 2 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- 19 pin micro HDMI Type D - male
- 3D-Transmission
- Limited lifetime warranty
- Cable Type
- 34
- Jacket Material
- PVC
- Length
- 2 m
- Plated Connector
- Gold
- 3D-Transmission
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
