StarTech.com 2m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M
Quicklinx: 85DPWS00 Mfr#: HDADMM2M
Type: HDMI
Length: 2m
More than 50 In Stock
£9.37 ex VAT
£11.24 inc VAT
The HDADMM2M 2-meter High Speed HDMI to HDMI Micro cable enables you to connect devices with an HDMI Micro port to a display/device with a standard HDMI port - a cost-saving solution for connecting cutting-edge and next-generation HDMI-capable devices to existing HDMI technology. The HDMI/HDMI Micro cable features high-quality gold-tipped connectors that ensure peak connectivity.
  • High compatibility
    The cable features a 19-pin HDMI Type-A connector and a male micro HDMI Type D connector, making it compatible with a variety of devices including cameras and tablets.
  • Durable construction
    With a robust PVC jacket and gold-plated connectors, this HDMI cable is designed to withstand everyday use while ensuring reliable signal transmission.
  • Efficient data transfer
    The 34 AWG cable design allows for efficient high-speed data transfer, making it ideal for streaming high-definition content and gaming.
  • 3D support
    This cable supports 3D transmission, delivering a rich and engaging visual experience when connected to compatible devices.
  • Environmentally friendly
    The cable complies with RoHS standards, ensuring it is free from hazardous substances and contributing to sustainable practices.
StarTech.com 2m High Speed HDMI Cable with Ethernet HDMI to HDMI Micro - HDMI cable with Ethernet - 2 m
Cable
American Wire Gauge (AWG)
34
Length
2 m
Connector
HDMI - male
Connector (Second End)
19 pin micro HDMI Type D - male
3D-Transmission
Cable Type
34
Jacket Material
PVC
Length
2 m
Plated Connector
Gold
3D-Transmission
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
85DP StarTech.com 1m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M In Stock £7.92
85DP StarTech.com 2m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M In Stock £9.37
85DP StarTech.com 0.5m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M In Stock £6.18
85DP StarTech.com 3m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M In Stock £11.17
Type: HDMI
Length: 2m
