The HDDVIMM2M, 2-meter HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A high quality addition to any home theater, digital signage or multimedia application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
- StarTech.com 2m High Speed HDMI Cable to DVI Digital Video Monitor - adapter cable - HDMI / DVI - 2 m
- Cable
- Adapter cable - HDMI / DVI
- American Wire Gauge (AWG)
- 28
- Length
- 2 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- DVI-D - male
- Limited lifetime warranty
- Cable Type
- Adapter cable
- Interface Supported
- HDMI / DVI
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 2 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- 18+1 pin digital DVI (Single-Link) - male
- RoHS
- Limited warranty - lifetime
