StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor
Quicklinx: 7TGMWS00 Mfr#: HDDVIMM2M
Type: A/V
Length: 2m
More than 50 In Stock
£10.42 ex VAT
£12.50 inc VAT
The HDDVIMM2M, 2-meter HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A high quality addition to any home theater, digital signage or multimedia application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
  • Reliable connectivity
    This cable provides a dependable connection between HDMI sources and DVI displays, ensuring compatibility and ease of use.
  • Enhanced shielding
    The aluminum mylar foil and braid shielding effectively minimize signal interference, maintaining high-quality audio and video transmission.
  • Durable construction
    Crafted with a robust PVC jacket, this cable is designed to withstand regular use while providing reliable performance over time.
  • High-quality connectors
    Gold-plated connectors offer superior conductivity and corrosion resistance, enhancing connection quality and longevity.
  • Universal compatibility
    The cable supports various multimedia devices, making it suitable for a range of applications, from home entertainment to professional presentations.
StarTech.com 2m High Speed HDMI Cable to DVI Digital Video Monitor - adapter cable - HDMI / DVI - 2 m
Cable
Adapter cable - HDMI / DVI
American Wire Gauge (AWG)
28
Length
2 m
Connector
HDMI - male
Connector (Second End)
DVI-D - male
Cable Type
Adapter cable
Interface Supported
HDMI / DVI
28
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
18+1 pin digital DVI (Single-Link) - male
RoHS
Limited warranty - lifetime
7TGM StarTech.com 10m HDMI to DVI-D Cable - M/M In Stock £51.54
7TGM StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor In Stock £10.42
7TGM StarTech.com 3m HDMI to DVI-D Cable - M/M In Stock £10.11
7TGM StarTech.com 5m HDMI to DVI-D Cable – M/M In Stock £18.85
7TGM StarTech.com 1m HDMI to DVI-D Cable - M/M In Stock £7.89
7TGM StarTech.com 0.5m HDMI to DVI-D Cable - M/M In Stock £7.58
Type: A/V
Length: 2m
