The HDDVIMM2M, 2-meter HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A high quality addition to any home theater, digital signage or multimedia application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
Reliable connectivity
This cable provides a dependable connection between HDMI sources and DVI displays, ensuring compatibility and ease of use. -
Enhanced shielding
The aluminum mylar foil and braid shielding effectively minimize signal interference, maintaining high-quality audio and video transmission. -
Durable construction
Crafted with a robust PVC jacket, this cable is designed to withstand regular use while providing reliable performance over time. -
High-quality connectors
Gold-plated connectors offer superior conductivity and corrosion resistance, enhancing connection quality and longevity. -
Universal compatibility
The cable supports various multimedia devices, making it suitable for a range of applications, from home entertainment to professional presentations.
- Startech 2m High Speed HDMI Cable to DVI Digital Video Monitor - adapter cable - HDMI / DVI - 2 m
- Cable
- Adapter cable - HDMI / DVI
- American Wire Gauge (AWG)
- 28
- Cable Length
- 2 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- DVI-D - male
- Limited lifetime warranty
- Cable Type
- Adapter cable
- Interface Supported
- HDMI / DVI
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Cable Length
- 2 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- 18+1 pin digital DVI (Single-Link) - male
- RoHS
- Limited warranty - lifetime
StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor | In Stock | £7.74 |
StarTech.com 3m HDMI to DVI-D Cable - M/M | In Stock | £9.42 |
StarTech.com 5m HDMI to DVI-D Cable – M/M | In Stock | £9.75 |
StarTech.com 1m HDMI to DVI-D Cable - M/M | In Stock | £7.14 |
StarTech.com 0.5m HDMI to DVI-D Cable - M/M | In Stock | £7.46 |
