StarTech.com 2m DVI to VGA Display Monitor Cable M/M - DVI to VGA (15 Pin)
Quicklinx: 8G3RWS00 Mfr#: DVIVGAMM2M
Length: 2m
11 In Stock
£8.60 ex VAT
£10.32 inc VAT
Connect a VGA display to a PC or Mac with a DVI Analog Video Card. The DVIVGAMM2M DVI to VGA Display Monitor Cable (2m) features a DVI-A male connector and a VGA male connector, enabling you to connect a VGA display to a PC or Mac computer with a DVI-I analog output.
  • Durable Construction
    The cable is designed with strain relief which helps to prevent wear and tear over time, ensuring longevity and reliability during use.
  • High-Quality Connectors
    Equipped with gold and nickel plated connectors, this cable ensures effective signal transmission and durability against corrosion.
  • Secure Fit
    Molded connectors combined with thumbscrews allow for a tight and secure connection to prevent any accidental disconnections.
  • Shielded Technology
    The shielded design provides protection against electromagnetic interference, ensuring crisp video quality.
  • Mac Compatibility
    Specifically designed to work with Mac systems, this cable facilitates easy connectivity for display setups.
StarTech.com 2m DVI to VGA Display Monitor Cable M/M DVI to VGA (15 Pin) - video cable - 2 m
Video cable
Shielded
Molded, thumbscrews, strain relief
Length
2 m
Connector
HD-15 (VGA) - male
Connector (Second End)
DVI-A - male
RoHS
Video cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Gold, nickel
Length
2 m
Connector
12+5 pin analogue DVI - male
RoHS
8G3R StarTech.com 1m DVI to VGA Display Monitor Cable M/M - DVI to VGA (15 Pin) In Stock £6.72
8G3R StarTech.com 2m DVI to VGA Display Monitor Cable M/M - DVI to VGA (15 Pin) In Stock £8.60
Length: 2m
