StarTech.com 2m DVI-D Dual Link Monitor Extension Cable - M/F
Quicklinx: 84LZWS00 Mfr#: DVIDDMF2M
Length: 2m
£7.95 ex VAT
£9.54 inc VAT
Extend the connection distance between your DVI-D digital devices by 2 meters. The DVIDDMF2M 2m DVI-D Dual Link Extension Cable allows you to extend the connection between your desktop workstation and DVI monitor, or your laptop and projector by up to 2-meters.
The dual link cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
This durable DVI male to female cable is designed to provide a high quality digital video experience.
StarTech.com 2m DVID Dual Link Monitor Extension Cable M/F - DVI extension cable - 2 m
DVI extension cable - dual link
Length
2 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
RoHS
DVI extension cable
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Plated Connector
Nickel
Length
2 m
Connector
24+1 pin digital DVI - male
24+1 pin digital DVI - female
RoHS
Length: 2m
Price Range Ex VAT: 0 - 50
