StarTech.com 2m DP 1.2 Cable - 10 Pack
Quicklinx: J1JZWS00 Mfr#: DISPL2M10PK
19 In Stock
£60.98 ex VAT
£73.17 inc VAT
The 2m VESA Certified DisplayPort 1.2 Cable offers reliable connectivity for high-resolution displays. This shielded cable supports 4K resolution at 60Hz and a data rate of 21.6 Gbps, ensuring smooth video and audio performance. With features like EMI protection and DisplayPort Multi-Stream Transport (MST), it allows for multiple display connections without sacrificing quality. Built to last, the cable is crafted with aluminum mylar foil and braid shielding, providing durability and interference resistance. The latched design of the 20 pin DisplayPort connectors ensures a secure connection, making it ideal for various applications ranging from professional environments to personal setups.
  • Reliable connection
    This DisplayPort cable is designed with high-quality components to provide a steady connection for your devices, ensuring an uninterrupted viewing experience.
  • High resolution support
    With support for 4K resolution at 60Hz, this cable allows for stunning visuals and clarity, making it suitable for gaming, graphic design, and multimedia presentations.
  • Excellent performance
    The cable's capability of handling 21.6 Gbps data rate ensures that even high-bandwidth applications run smoothly and efficiently.
  • Enhanced shielding
    The aluminum mylar foil with braid construction provides shielding against electromagnetic interference, which is essential for maintaining signal integrity.
StarTech.com 2m VESA Certified DisplayPort 1.2 Cable - 10 Pack - 4K 60Hz - DisplayPort cable - DisplayPort to DisplayPort - 2 m
DisplayPort cable
Packaged Quantity
10 (specifications are for single item)
Shielded
4K60Hz UHD support, stereo 3D, 21.6 Gbps data rate, 8 audio channels, DisplayPort Multi-Stream Transport (MST), EMI protection, HBR2 support
Length
2 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 1.2
Packaged Quantity
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
28
Length
2 m
Outside Diameter
7.3 mm
134 g
Connector
DisplayPort 1.2, CMG, RoHS
Shipping Width
35 cm
Shipping Depth
8 cm
Shipping Height
46 cm
Shipping Weight
1.5 kg
