StarTech.com 2m Dock Connector to USB Cable for Samsung Galaxy Tab
Quicklinx: 8GN5WS00 Mfr#: USB2SDC2M
Length: 2m
Select:
  • 2m
£4.75 ex VAT
£5.70 inc VAT
Charge or sync your Samsung Galaxy Tab Computer. The USB2SDC2M 2-meter Samsung Galaxy Tab Dock Connector to USB Cable features one (30-pin) Samsung male connector and one (4-pin) USB Type 'A' male connector, delivering a simple way to connect your Samsung Galaxy Tab to a USB-capable computer.
For convenient syncing and charging, the Dock Connector/USB Cable can be connected to a computer USB port for data transfers or for charging while you are working, or to a USB power adapter for simple charging from an available (wall) power outlet.
The dock connector to USB cable for Samsung Galaxy Tab is designed and constructed for maximum durability, making it a dependable replacement for damaged or misplaced sync cables.
StarTech.com 2m Dock Connector to USB Cable for Samsung Galaxy Tab - galaxy tablet Cable - Samsung tab Cable (USB2SDC2M) - charging / data cable - 2 m
Cable
Charging / data cable
Shielded
American Wire Gauge (AWG)
24/28
Length
2 m
Connector
USB - male
Connector (Second End)
Samsung 30-pin Dock Connector - male
Samsung Galaxy Tab, Tab 10.1, Tab 10.1 WiFi, Tab 10.1N, Tab 10.1N WiFi, Tab 10.1V, Tab 2 (10.1), Tab 2 (10.1) WiFi, Tab 2 (7.0), Tab 2 (7.0) WiFi, Tab 7.0 Plus, Tab 7.0 Plus N, Tab 7.0 Plus N WiFi, Tab 7.0 Plus WiFi, Tab 7.7, Tab 7.7 WiFi, Tab 8.9, Tab 8.9 WiFi, Tab WiFi
Cable Type
Shielded
24/28
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Nickel
Recommended Use
Tablet
Connector
4 pin USB Type A - male
RoHS
Limited warranty - lifetime
8GN5 StarTech.com 5in Micro USB to USB OTG Host Adapter M/F In Stock £5.53
Length: 2m
