StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable
Quicklinx: 8JFMWS00 Mfr#: SFPCMM2M
Type: Cable
Hurry, only 2 left in stock!
£40.56 ex VAT
£48.67 inc VAT
Connect 10GbE SFP+ network devices with this high-quality replacement SFP-H10GB-CU2M cable. The SFPCMM2M Cisco Compatible 2m SFP+ cable is a fully hot pluggable, direct attach cable, supporting 10 Gigabit Ethernet and Fiber Channel applications connected through (Small Form Factor Pluggable) SFP+ ports.
Designed for short length, high speed interconnects, this low power, low latency Twinax cable is a cost-effective alternative to fiber optic cable assemblies and is intended for short distance applications such as point-to-point in-rack and across rack network switch/server connections.
This 10GBASE-CU SFP+ Cable is compliant with MSA (Multi-Source Agreement) standards, making it a reliable replacement SFP-H10GB-CU2M cable.
  • Reliable Connection
    The latching connectors provide a secure and stable connection, ensuring minimal interruptions in data flow.
  • Efficient Data Transmission
    Utilizing twinaxial technology, this cable is designed to enhance data transmission speeds while reducing interference.
  • Environmentally Friendly
    Compliant with RoHS standards, this cable contributes to environmental protection by limiting hazardous substances.
  • Flexible Operating Range
    Designed to function effectively in a temperature range from 0°C to 70°C, making it versatile for different setups.
StarTech.com Cisco SFP-H10GB-CU2M Compatible 2m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10 Gbps Low Power Passive Transceiver Module DAC, Cisco Firepower ASR920 - Lifetime Warranty (SFPCMM2M) - direct attach cable - 2 m
Direct attach cable
Twinaxial
Latching connectors
Length
2 m
Connector
SFP+
Connector (Second End)
SFP+
P/N: ET10GSFP, PEX10000SFPI, PEX10GSFP4I, PEX20000SFPI
Network Cable Type
Direct attach cable
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Latching connectors
Length
2 m
Connector
SFP+
SFP+
RoHS
70 °C
8JFM StarTech.com 1m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £36.36
8JFM StarTech.com 2m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £40.56
8JFM StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £46.24
8JFM StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable In Stock £60.13
Type: Cable
