The 2m Blue CAT8 Ethernet Cable from StarTech.com is designed to deliver performance for high-bandwidth applications, supporting speeds of up to 40 Gbps. With its robust aluminum mylar foil shielding, this cable mitigates EMI, promoting a stable connection essential for data transmission. The pure bare copper conductors ensure optimal signal quality while the flame-retardant and low smoke zero halogen materials enhance safety, making this cable suitable for various environments. Additionally, the strain relief design extends the lifespan of the connectors, allowing for up to 750 mating cycles, ensuring durability throughout extensive use.
This patch cable complies with IEEE standards, including IEEE 802.3bt and IEEE 802.3ba, ensuring compatibility with a range of devices. The RJ-45 male connectors on both ends support 100W PoE++ for powering devices over the network. The snagless design further protects the connectors from damage during installation, while the T568B wiring scheme promotes seamless integration into existing network setups. Ideal for home and professional use, this cable provides a reliable network solution.
High-performance speed
Delivers data transfer rates of up to 40 Gbps, suitable for demanding applications. -
Robust shielding
Features aluminum mylar foil with a braid to protect against EMI interference and enhance signal integrity. -
Durable connectors
RJ-45 male connectors provide a reliable connection and are designed for up to 750 mating cycles. -
Safe and compliant materials
Constructed with low smoke zero halogen materials, ensuring safety in fire situations. -
High power capability
Supports 100W PoE++ for powering devices over the network, streamlining installations.
- StarTech.com 2m Blue CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 2 m - blue
- Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Shielding Material
- Aluminum mylar foil with braid
- Wires per Cable
- 8 wires
- Snagless, halogen-free, passive cable, up to 40 Gbps, 100W PoE++ support, pure bare copper conductors, strain relief, test fluke pass, EMI protection, 750 mating cycles, flame retardant
- Length
- 2 m
- Diameter
- 5.6 mm
- Core / Cladding Diameter
- 50 micron
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- 50 micron
- Plated Connector
- Gold
- Length
- 2 m
- Diameter
- 5.6 mm
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- TIA/EIA T568B - up to 2000 MHz
- Shipping Width
- 22 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 93 g
- 0 °C
- 50 °C
