StarTech.com 2m CAT8 Ethernet Cable, LSZH
Quicklinx: J1LNWS00 Mfr#: NLBL-2M-CAT8-PATCH
21 In Stock
£20.13 ex VAT
£24.15 inc VAT
The 2m Blue CAT8 Ethernet Cable from StarTech.com is designed to deliver performance for high-bandwidth applications, supporting speeds of up to 40 Gbps. With its robust aluminum mylar foil shielding, this cable mitigates EMI, promoting a stable connection essential for data transmission. The pure bare copper conductors ensure optimal signal quality while the flame-retardant and low smoke zero halogen materials enhance safety, making this cable suitable for various environments. Additionally, the strain relief design extends the lifespan of the connectors, allowing for up to 750 mating cycles, ensuring durability throughout extensive use.
This patch cable complies with IEEE standards, including IEEE 802.3bt and IEEE 802.3ba, ensuring compatibility with a range of devices. The RJ-45 male connectors on both ends support 100W PoE++ for powering devices over the network. The snagless design further protects the connectors from damage during installation, while the T568B wiring scheme promotes seamless integration into existing network setups. Ideal for home and professional use, this cable provides a reliable network solution.
  • High-performance speed
    Delivers data transfer rates of up to 40 Gbps, suitable for demanding applications.
  • Robust shielding
    Features aluminum mylar foil with a braid to protect against EMI interference and enhance signal integrity.
  • Durable connectors
    RJ-45 male connectors provide a reliable connection and are designed for up to 750 mating cycles.
  • Safe and compliant materials
    Constructed with low smoke zero halogen materials, ensuring safety in fire situations.
  • High power capability
    Supports 100W PoE++ for powering devices over the network, streamlining installations.
StarTech.com 2m Blue CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 2 m - blue
Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
S/FTP
Wiring Scheme
T568B
Shielding Material
Wires per Cable
8 wires
Snagless, halogen-free, passive cable, up to 40 Gbps, 100W PoE++ support, pure bare copper conductors, strain relief, test fluke pass, EMI protection, 750 mating cycles, flame retardant
Length
2 m
Diameter
5.6 mm
Core / Cladding Diameter
50 micron
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
S/FTP
Wiring Scheme
T568B
Shielding Material
Jacket Material
Low Smoke Zero Halogen (LSZH)
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
50 micron
Plated Connector
Gold
Length
2 m
Diameter
5.6 mm
Blue
Connector
RJ-45 - male
RJ-45 - male
TIA/EIA T568B - up to 2000 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
1.5 cm
Shipping Weight
93 g
50 °C
