StarTech.com 2m CAT6a Ethernet Cable LSZH - White
Quicklinx: H15MWS00 Mfr#: NLWH-2M-CAT6A-PATCH
Length: 2m
Colour: White
20 In Stock
£10.80 ex VAT
£12.96 inc VAT
The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
Available in a variety of lengths and colors, the shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
  • Reliable Connectivity
    This 2m CAT6a Ethernet cable features RJ-45 connectors on both ends, providing a secure connection for networking equipment with male connectors. The cable employs a foil shielding material to enhance performance and reduce interference.
  • High Performance
    Designed to support speeds of up to 10 Gbps and a maximum input power of 100 watts, this cable delivers performance for demanding data applications. The tested frequency reaches up to 500 MHz, making it suitable for various networks.
  • Durability and Safety
    With a Low Smoke Zero Halogen (LSZH) jacket, this patch cable is suitable for environments where fire safety is a priority. Its molded design and strain relief features protect against cable damage and ensure a long-lasting performance.
StarTech.com 2m CAT6a Ethernet Cable - White - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 2 m - white
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
75.2 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
1.5 cm
Shipping Weight
83.9 g
Length: 2m
Colour: White
