StarTech.com 2m CAT6a Ethernet Cable LSZH - Black
Quicklinx: H14ZWS00 Mfr#: NLBK-2M-CAT6A-PATCH
Length: 2m
Colour: Black
£9.85 ex VAT
£11.82 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 2m - Black - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Enhanced connectivity
    Experience seamless network performance with the StarTech.com 2m CAT6a Ethernet Cable, designed to support up to 10 Gbps speeds and a bandwidth of 500 MHz. This high-quality cable ensures rapid data transfer and minimal lag, making it ideal for intensive online tasks, streaming, and gaming.
  • Robust construction
    Crafted with a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the risk of smoke and toxic fume emission in the event of a fire, providing a safer environment. The combination of snagless connectors and strain relief design protects the cable from damage and wear over time, ensuring a durable and reliable connection.
  • Superior performance
    Featuring EMI/RFI protection, minimized Near-End Crosstalk (NEXT), and reduced Return Loss (RL), this cable is engineered to deliver flawless signal quality. The gold-plated RJ-45 connectors ensure a secure connection and optimal signal clarity, enhancing your network's overall performance.
StarTech.com 2m CAT6a Ethernet Cable - Black - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 2 m - black
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
75.2 g
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
1.5 cm
Shipping Weight
83.9 g
Length: 2m
Colour: Black
