StarTech.com 2m CAT6a Ethernet Cable LSZH - Aqua
Quicklinx: H14MWS00 Mfr#: NLAQ-2M-CAT6A-PATCH
16 In Stock
£10.80 ex VAT
£12.96 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 2m - Turquoise - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Efficiency in signal transmission
    This patch cable supports up to 10 Gbps, ensuring fast network performance for various applications.
  • Enhanced protection against interference
    Featuring foil shielding and EMI/RFI protection, this cable minimizes signal degradation for reliable data transfer.
  • Safe and reliable construction
    The Low Smoke Zero Halogen (LSZH) jacket reduces the risk of toxic emissions in the event of a fire, promoting a safer environment.
  • User-friendly design
    Equipped with snagless connectors and strain relief features, this cable is designed to withstand bends and pulls without damage.
  • Compliance with industry standards
    Meets RoHS, ETL, WEEE, and ANSI/TIA-568.2-D standards, ensuring quality and safety in wiring systems.
StarTech.com 2m CAT6a Ethernet Cable - Aqua - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 2 m - aqua
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Aqua
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
75.2 g
Aqua
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
1.5 cm
Shipping Weight
83.9 g
