StarTech.com 2m BS-1363 to C13 Y-Cable
Quicklinx: C9JLWS00 Mfr#: PXT101YUK
Type: Cable
More than 50 In Stock
£8.44 ex VAT
£10.12 inc VAT
Power two devices at once from a single power outlet, perfect for dual-monitor setups. This C13 Y-cable lets you plug multiple devices into a single power outlet, to maximize the space on your power strip, surge protector or wall outlet. It's perfect for setting up dual-monitor workstations.
The cable length from the Y-split is 47 cm on each side. This gives you an extended reach for connecting to two monitors securely, without placing a strain on the cable.
The power-splitter cable can also be used for connecting a monitor and computer to the same outlet or any two devices that have a C13 power connection.
The PXT101YUK is built to exact specifications and is fully tested to ensure maximum performance.
StarTech 6ft (2m) UK Computer Power Cable Y Splitter, 18AWG, BS 1363 to 2x C13 Power Cord, 10A 250V, Replacement AC Power Cord, Monitor Power Cable, BS 1363 to 2x IEC C13 Kettle Lead - PC Power Supply Cable - power splitter - BS 1363 to power IEC 60320 C13 - 1.8 m
Power splitter
Service Vacuum Thermoplastic (SVT) jacket
Cable Length
1.8 m
United Kingdom
Connector
Power BS 1363 - male
Connector (Second End)
2 x power IEC 60320 C13
Rated Voltage
AC 250 V
Rated Current
10 A
Power splitter
Jacket Material
PVC
Rated Voltage
AC 250 V
Rated Current
10 A
Cable Length
1.8 m
United Kingdom
Connector
RoHS
C9JL StarTech.com 6 ft Standard UK Computer Power Cord In Stock £6.56
C9JL StarTech.com 3m UK Computer Power Cord - 3 Pin Mains Lead - C13 to BS-1363 In Stock £6.11
C9JL StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
C9JL StarTech.com Monitor Mount - USB Passthrough In Stock £161.64
C9JL StarTech.com Dual Monitor Mount - Stackable In Stock £217.58
C9JL StarTech.com Dual Monitor Stand In Stock £82.12
Type: Cable
