Power two devices at once from a single power outlet, perfect for dual-monitor setups. This C13 Y-cable lets you plug multiple devices into a single power outlet, to maximize the space on your power strip, surge protector or wall outlet. It's perfect for setting up dual-monitor workstations.
The cable length from the Y-split is 47 cm on each side. This gives you an extended reach for connecting to two monitors securely, without placing a strain on the cable.
The power-splitter cable can also be used for connecting a monitor and computer to the same outlet or any two devices that have a C13 power connection.
The PXT101YUK is built to exact specifications and is fully tested to ensure maximum performance.
- StarTech 6ft (2m) UK Computer Power Cable Y Splitter, 18AWG, BS 1363 to 2x C13 Power Cord, 10A 250V, Replacement AC Power Cord, Monitor Power Cable, BS 1363 to 2x IEC C13 Kettle Lead - PC Power Supply Cable - power splitter - BS 1363 to power IEC 60320 C13 - 1.8 m
- Power splitter
- Service Vacuum Thermoplastic (SVT) jacket
- Cable Length
- 1.8 m
- Localisation
- United Kingdom
- Connector
- Power BS 1363 - male
- Connector (Second End)
- 2 x power IEC 60320 C13
- Rated Voltage
- AC 250 V
- Rated Current
- 10 A
- Black
- Limited lifetime warranty
- Power splitter
- Jacket Material
- PVC
- Rated Voltage
- AC 250 V
- Rated Current
- 10 A
- Cable Length
- 1.8 m
- Black
- Localisation
- United Kingdom
- Connector
- RoHS
StarTech.com 6 ft Standard UK Computer Power Cord | In Stock | £6.56 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £139.14 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £161.64 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £217.58 |
StarTech.com Dual Monitor Stand | In Stock | £82.12 |
