StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F
Quicklinx: 8G43WS00 Mfr#: MXT1002MBK
Length: 2m
Hurry, only 1 left in stock!
£3.00 ex VAT
£3.60 inc VAT
Extend the connection between your DB9 serial devices by up to 2m. The MXT1002MBK Black Serial Extension Cable (2m) features one DB9 male connector and one DB9 female connector, providing a high quality extension for your RS232 serial devices, which enables you to position your peripheral devices as needed.
  • Reliable shielded construction
    The shielded design of the cable protects against electromagnetic interference, providing a stable connection for data transfer, which is crucial for reliable communication.
  • Flexible length
    At 2 m, this extension cable allows for distance between devices without losing quality or connectivity, making it ideal for various installation scenarios.
  • Durable nickel plated connectors
    The nickel plating on the connectors offers protection against wear and tear, ensuring consistent performance over time and in diverse environments.
  • Compliant with safety standards
    This cable meets RoHS compliance standards, highlighting its safe manufacturing processes while being environmentally conscious.
StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - DB9 RS232 Serial Extension Cable - Male to Female Cable (MXT1002MBK) - serial extension cable - DB-9 to DB-9 - 2 m
Serial extension cable
Shielded
Length
2 m
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
P/N: 1P3FPC-USB-SERIAL, IC232TTL, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232D, ICUSB232PRO, ICUSB232V2, SV1108IPPWGB
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
2 m
Connector
RoHS
8G43 StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.15
8G43 StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £3.00
8G43 StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.03
8G43 StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.13
Length: 2m
Stock Status: While stocks last
Stock Status: Clearance
