Connect your serial devices, and transfer your files. The SCNM9FF2MBK 2m DB9 Null Modem Cable features two DB9 female connectors, allowing you to connect a serial device to a 9-pin serial port, or transfer files directly from PC to PC via a serial connection.
- StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/F - DB9 Female to Female - 9 pin RS232 Null Modem Cable - 2 meter, Black - null modem cable - DB-9 to DB-9 - 2 m
- Null modem cable
- Molded, thumbscrews, EMI protection
- Length
- 2 m
- Connector
- 9 pin D-Sub (DB-9) - female
- Connector (Second End)
- Black
- Limited lifetime warranty
- Designed For
- P/N: PCI2S5502, PEX4S953, PEX4S953LP
- Null modem cable
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 2 m
- Black
- Connector
- RoHS
- Designed For
StarTech.com 1m Black DB9 Null Modem Cable | In Stock | £3.95 |
StarTech.com 2m Black DB9 Null Modem Cable | In Stock | £4.53 |
StarTech.com RS232 Serial Null Modem Cable | In Stock | £7.76 |
