StarTech.com 2m Aqua OM4 LC Fiber Cable
Quicklinx: CZCRWS00 Mfr#: 450FBLCLC2
Length: 2m
Colour: Aqua
47 in stock
£20.02 ex VAT
£24.02 inc VAT
Connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. This fiber optic cable lets you connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. The OM4 cable supports Vertical Cavity Surface Emitting Laser (VCSEL) and LED light sources and is backward compatible with your existing 50/125 equipment.
This Aqua OM4 duplex multimode fiber cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. It's ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each OM4 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
StarTech.com Aqua OM4 Duplex Multimode Fiber - 2m / 6 ft - 100 Gb - 50/125 - OM4 Fiber - LC to LC Fiber Patch Cable (450FBLCLC2) - network cable - 2 m - aqua
Network cable - OM4
Fibre optic
Type of Fibre Optics
Multimode
Laser-optimized multimode fibre (LOMMF), VCSEL array technology
Length
2 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Aqua
Network Cable Type
Network cable - OM4
Fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
50 / 125 micron
Length
2 m
Aqua
Connector
RoHS - up to 3500 MHz
CZCR StarTech.com 1m Aqua OM4 LC Fiber Cable In Stock £18.26
CZCR StarTech.com 2m Aqua OM4 LC Fiber Cable In Stock £20.02
CZCR StarTech.com 5m Aqua OM4 LC Fiber Cable In Stock £21.87
CZCR StarTech.com 3m Aqua OM4 LC Fiber Cable In Stock £24.78
Length: 2m
Colour: Aqua
Price Range Ex VAT: 0 - 50
