Connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. This fiber optic cable lets you connect 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in 40 and 100 Gigabit networks. The OM4 cable supports Vertical Cavity Surface Emitting Laser (VCSEL) and LED light sources and is backward compatible with your existing 50/125 equipment.
This Aqua OM4 duplex multimode fiber cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. It's ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each OM4 fiber cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Performance technology
Utilizes fiber optic technology with Laser-optimized multimode fiber, enabling efficient data transmission with minimal loss. -
Safe design
Constructed with a Low Smoke Zero Halogen (LSZH) jacket to reduce toxic emissions in case of fire, prioritizing user safety. -
Equipped with dual LC multi-mode male connectors, ensuring compatibility with a wide range of network devices.
- StarTech.com Aqua OM4 Duplex Multimode Fiber - 2m / 6 ft - 100 Gb - 50/125 - OM4 Fiber - LC to LC Fiber Patch Cable (450FBLCLC2) - network cable - 2 m - aqua
- Network cable - OM4
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Laser-optimized multimode fibre (LOMMF), VCSEL array technology
- Length
- 2 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 50 / 125 micron
- Length
- 2 m
- Aqua
- Connector
- RoHS - up to 3500 MHz
StarTech.com 1m Aqua OM4 LC Fiber Cable | In Stock | £18.27 |
StarTech.com 2m Aqua OM4 LC Fiber Cable | In Stock | £19.60 |
StarTech.com 5m Aqua OM4 LC Fiber Cable | In Stock | £22.07 |
StarTech.com 3m Aqua OM4 LC Fiber Cable | In Stock | £23.25 |
StarTech.com 10m OM4 LC Multimode Duplex Fiber Optic Patch Cable Aqua | In Stock | £40.18 |
StarTech.com 7m OM4 LC Multimode Duplex Fiber Optic Patch Cable - Aqua | In Stock | £32.53 |
StarTech.com 15m OM4 LC-LC Multimode Duplex Fiber Optic Patch Cable Aqua | In Stock | £52.85 |
