Connect USB 3.0 USB-B devices to your USB Type-C or Thunderbolt 3 computer. This USB-C to USB-B cable lets you connect your USB 3.0 peripheral devices, such as a printer, external drive or docking station to your USB Type-C laptop or tablet. The cable is also compatible with Thunderbolt 3 ports.
Note: USB 3.0 is also known as USB 3.1 Gen 1 (5Gbps).
Efficient data transfer
The USB C to USB B Printer Cable supports a data transfer rate of 5 Gbps, ensuring rapid communication between your devices. -
Flexible length
At 6 ft / 2 m in length, this cable provides ample reach for connecting devices without compromising on flexibility and positioning. -
Broad compatibility
Designed to meet USB 3.0 and USB 3.1 Gen 1 standards, this cable is compatible with a wide range of USB devices, facilitating seamless integration. -
Durable design
Constructed with high-quality materials, this cable is built to withstand daily use while providing reliable performance. -
Versatile connectivity
Featuring male USB-C and male USB Type-B connectors, the cable ensures a dependable connection for printers and other peripherals.
- StarTech.com USB C to USB B Printer Cable - 6 ft / 2m - USB C Printer Cable - USB C to USB B Cable - USB Type C to Type B (USB315CB2M) - USB cable - 24 pin USB-C to USB Type B - 2 m
- USB cable
- 5 Gbps data rate
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 9 pin USB Type B - male
- USB 3.0/ USB 3.1 Gen 1
- 2-year warranty
- Designed For
- P/N: HB30A3A1CST, HB30C3A1CST, HB30C5A2CSC, HB30C5A2CST, HBS304A24A, MST30C2HDPPD, SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
- USB cable
- 5 Gbps data rate
- Length
- 2 m
- Connector
- 2-year warranty
- Designed For
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £100.50 |
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £39.74 |
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) | In Stock | £52.91 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £49.11 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £64.50 |
StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £113.49 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £10.11 |
StarTech.com 10 Port Industrial USB 3.0 Hub | In Stock | £133.39 |
StarTech.com 10-Pt USB 3.0 Hub w/ Charging | In Stock | £65.55 |
StarTech.com 4-Port USB 3 Hub + 2.4A DCP | In Stock | £43.92 |
StarTech.com 7-Pt USB 3.0 Hub + Charge Pts | In Stock | £58.25 |
StarTech.com 2m 6ft USB 2.0 C to B Cable | In Stock | £13.66 |
StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £41.24 |
StarTech.com 3m USB 2.0 C to B Cable | In Stock | £16.40 |
StarTech.com 0.5m USB 2.0 C to B Cable | In Stock | £8.90 |
StarTech.com 4PT USB 3.0 Hub - Charge Port | In Stock | £31.93 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £16.96 |
