StarTech.com 2m 6ft USB 2.0 USB-C Cable
Quicklinx: CKZ1WS00 Mfr#: USB2CC2M
Length: 2m
27 In Stock
£11.19 ex VAT
£13.42 inc VAT
Charge your USB 2.0 USB-C devices, over longer distances. This USB-C to USB-C cable makes it easy to charge and sync USB Type-C devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, using the USB-C port on your computer.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
The 2-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, your mobile device will reach your computer or wall charger more comfortably.
With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
Replace the USB-C cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all of your USB-C devices.
StarTech.com 2m 6 ft USB C Cable - M/M - USB 2.0 - USB-IF Certified - USB-C Charging Cable - USB 2.0 Type C Cable (USB2CC2M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Double shielded
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Thunderbolt 3 / USB 2.0
P/N: DKT30CHD, HB30C1A1CPD, HB30C3A1CFBW
USB-C cable
Double shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Length
2 m
42 g
Connector
24 pin USB-C - male
24 pin USB-C - male
Thunderbolt 3 / USB 2.0, RoHS
CKZ1 StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.01
CKZ1 StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.24
CKZ1 StarTech.com USB-C to Micro-USB Adapter M/F In Stock £4.59
CKZ1 StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.87
CKZ1 StarTech.com 2m 6ft USB 2.0 USB-C Cable In Stock £11.19
CKZ1 StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £15.43
CKZ1 StarTech.com 0.5m USB 2.0 USB C Cable In Stock £8.74
CKZ1 StarTech.com 1m Right Angle USB C Cable In Stock £10.49
CKZ1 StarTech.com 3m USB 2.0 Type C Cable In Stock £11.57
Length: 2m
