Connect USB 2.0 USB-B devices to your USB-C or Thunderbolt 3 computer. This USB-C to USB-B cable lets you connect your USB 2.0 peripheral devices, such as a printer, external drive or scanner to your USB Type-C laptop or tablet. The cable is also compatible with Thunderbolt 3 ports.
Reliable Connectivity
The 24 pin USB-C connector on one end ensures secure connectivity with modern devices, while the 4 pin USB Type-B connector is designed for compatibility with a wide range of printers and peripherals. -
Enhanced Durability
Made with aluminum mylar foil and braid shielding, this cable resists wear and interference, providing a stable connection for data transfer and device communication. -
Optimal Performance
With an American Wire Gauge of 22/30, this cable supports high-speed transmission rates, making it suitable for quick data exchanges and efficient printing tasks. -
Versatile Applications
This cable is ideal for connecting USB Type-C devices to USB Type-B equipment, allowing for seamless integration across various devices in professional and home environments. -
Environmentally Compliant
The cable adheres to RoHS and WEEE standards, ensuring it is manufactured with respect for the environment, aligning with modern eco-friendly practices.
- StarTech.com 2m 6ft USB C to USB B Cable - USB 2.0 - USB Type C Printer Cable M/M - USB 2.0 Type-C to Type-B Cable (USB2CB2M) - USB-C cable - 24 pin USB-C to USB Type B - 2 m
- USB-C cable
- Technology
- Shielded
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 pin USB Type B - male
- Thunderbolt 3 / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Length
- 2 m
- Black
- 63 g
- Connector
- Thunderbolt 3 / USB 2.0, RoHS, WEEE
