Create feature-rich HDMI connections that are certified to be error-free. This 2-meter High Speed HDMI cable has been tested in accordance with the Premium HDMI Cable Certification Program. This ensures it's able to deliver the newest technical features that the latest HDMI specifications have to offer, including enhanced resolutions and protection against EMI interference.
Each of the certified Premium High Speed HDMI Cables is labeled with a unique anti-counterfeiting authentication label so you can be confident that you have received a genuine certified cable.
The cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors.
With higher resolutions, increased speeds, and sharper images, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI capabilities available today. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage.
Plus, the cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices.
The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center to ensure it supports the high-bandwidth enabled features it promises. An EMI test is also performed to ensure the cable minimizes interference with wireless signals.
Each cable is labeled with the Premium HDMI Cable Authentication, so you can be confident that you are purchasing a high-quality premium cable with guaranteed performance.
The cable delivers dual video streams so that two videos can be viewed simultaneously on the same display. You can watch your favorite show while your kids play their favorite video game. Your display must support Multi-view in order to take advantage of dual video streams.
Experience the latest that HDMI has to offer
The cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors. With higher resolutions, increased speeds, and sharper images, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI capabilities available today. It's the perfect cable for creating dependable home theater connections or providing lifelike digital signage. Plus, the cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices. -
Provide superior connections with Premium HDMI certification
The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center. This gives you the assurance that the cable will deliver the high-bandwidth enabled features you need. An EMI test is also performed to ensure the cable minimizes interference with wireless signals. -
Watch dual video streams on a single display
The cable delivers dual video streams so that you can view two videos simultaneously on the same display. Your display must support Multi-View in order to take advantage of dual video streams. The HDMM2MP is backed by StarTech.com's Lifetime Warranty.
- Startech 6ft (2m) Premium Certified HDMI 2.0 Cable with Ethernet, High Speed Ultra HD 4K 60Hz HDMI Cable HDR10, HDMI Cord (Male/Male Connectors), For UHD Monitors, TVs, Displays - Durable HDMI Cable - HDMI cable with Ethernet - 2 m
- Cable
- American Wire Gauge (AWG)
- 30
- Cable Length
- 2 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- 4K format support, HDR support
- Limited lifetime warranty
- Designed For
- P/N: ADJPROJCART, CDPHDMDP2HD, DKT31CHPD3, DKT31CSDHPD3, EXTEND-HDMI-4K40C6P1, FPWHANGER, FPWTLTPORT, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, KITBXDOCKPEU, KITBXDOCKPNA, KITBXDOCKPUK, KITBZDOCK, MBLTVSTNDEC, PEXHDCAP4K, STNDMTVDUO, SV231DHU34K6, SV231HU34K6, SV431HU34K6, USBC-HDMI-CDP2HD4K60
- Cable Type
- 30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Cable Length
- 2 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS, WEEE
- Limited warranty - lifetime
- Designed For
- P/N: ADJPROJCART, CDP2DPHD, CDP2HD4K60, CDP2HD4K60H, CDP2HD4K60SA, CDP2HD4K60W, CDP2HDMDP, CDPHDMDP2HD, DK30A2DH, DKT31CHPD3, DKT31CSDHPD3, DP2HD4K60H, DP2HD4K60S, EXTEND-HDMI-4K40C6P1, FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWHANGER, FPWTLTBAT, FPWTLTPORT, HD202A, HDBOOST4K2, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, KITBXDOCKPEU, KITBXDOCKPNA, KITBXDOCKPUK, KITBZDOCK, MBLTVSTNDEC, MDP2HD4K60S, MOD4DOCKACPD, MSTCDP123HD, PEXHDCAP4K, ST122HD202, ST124HD202, STNDMTV100, STNDMTV70, STNDMTVDUO, SV231DHU34K6, SV231HU34K6, SV431HU34K6, TB32HD24K60, TB3DKM2HDL, USBC-HDMI-CDP2HD4K60, VS221HD20, VS421HD20, VS421HDDP
StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £9.20 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male | In Stock | £9.26 |
StarTech.com USB 3 to HDMI w/ USB Hub | In Stock | £60.64 |
StarTech.com HDMI Coupler / Gender Changer - F/F | In Stock | £8.59 |
StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £23.14 |
StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC | In Stock | £48.92 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.75 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.46 |
StarTech.com USB 3.0 to Dual HDMI Adapter | In Stock | £36.04 |
StarTech.com 5m 15ft Premium 4K HDMI Cable | In Stock | £24.69 |
StarTech.com 7m 23ft Premium 4K HDMI Cable | In Stock | £36.43 |
StarTech.com 0.5m Premium 4K HDMI Cable | In Stock | £9.95 |
StarTech.com Triple Monitor Desk Mount | In Stock | £178.05 |
StarTech.com Triple Monitor Desk Mount | In Stock | £169.08 |
StarTech.com Crossbar Dual Monitor Stand | In Stock | £86.32 |
StarTech.com Dual Monitor Vertical Mount | In Stock | £121.00 |
