StarTech.com 2m 6.6ft DisplayPort 1.4 Cable
Quicklinx: F2GBWS00 Mfr#: DP14MM2M
Type: DisplayPort
Length: 2m
49 In Stock
£11.86 ex VAT
£14.23 inc VAT
This DisplayPort 1.4 cable lets you connect your DP laptop or desktop computer to an ultra-high definition 8K monitor, TV or projector.
The DP monitor cable provides the essential final link in your audio-video setups and is ideal for: Delivering enriched presentations; Displaying crisp digital signage walls; Creating eye-catching visuals for photography, videography, cinematography; Producing lifelike gaming.
This DP cable is VESA certified to ensure full compliance and efficient operation of the higher link rate of HBR3. It has been tested to meet all DP 1.4 specifications to ensure quality and reliability.
This 8K DisplayPort cable supports all DP 1.4 features: Resolutions up to 8K (7680x4320) @ 60Hz, backward compatible with 5K (5120x2880) @ 60Hz and 4K(4096x2160) @ 120Hz and previous generations of DP; High Bit Rate 3 (HBR3) bandwidths of 32.4Gbps; High Dynamic Range (HDR) for higher contrast ratio and vivid colors; Multi-Stream Transport (MST) for daisy-chaining multiple monitors; Display Stream Compression 1.2 (DSC); Forward Error Correction; 32 uncompressed digital audio channels; HDCP 2.2.
The cable has a thinner 34 AWG construction that allows for flexible installation with minimal clutter, which is perfect for offsite assignments. Each connector features latches that provide secure connections between your devices.
  • High Performance
    This cable supports a maximum resolution of 7680x4320 at 60Hz, providing exceptional visuals for gaming and professional applications.
  • Advanced Audio Support
    With the capability to transmit 32 uncompressed digital audio channels, it delivers studio-quality sound alongside high-definition video.
  • Reliable Construction
    The latched connector design ensures a secure connection to devices, reducing the risk of accidental disconnections.
  • Versatile Compatibility
    Compliant with HDCP 2.2 and DSC 1.2 standards, this cable is compatible with a wide range of devices, including Chromebooks.
  • Flexible Design
    Its flexible build allows for easy maneuverability and installation in tight spaces, making it a practical solution for any setup.
StarTech 6ft/2m VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HBR3 HDR, Super UHD DisplayPort to DisplayPort Monitor Cord, Ultra HD 4K 120Hz DP 1.4 Slim Video Cable M/M DP Connectors - DP 1.4 Latching Cable - DisplayPort cable - DisplayPort to DisplayPort - 2 m
DisplayPort cable
8K support, flexible, Ultra HD (8K) support, HBR3 support, maximum resolution 7680x4320 at 60Hz, HDR support, 32 uncompressed digital audio channels, Multi-Stream Transport
Cable Length
2 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 1.4
Works With Chromebook
P/N: CDP2DPHD, SV231QDPU34K, TB32DP14
DisplayPort cable
Cable Length
2 m
Connector
DisplayPort 1.4, HDCP 2.2, DSC 1.2
F2GB StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.89
F2GB StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £11.86
F2GB StarTech.com 3m 9.8ft DisplayPort 1.4 Cable In Stock £23.75
F2GB StarTech.com 5m DisplayPort 1.4 Cable In Stock £30.35
Type: DisplayPort
Length: 2m
