Deliver fast, reliable, data transfers, safely, over high end networking equipment. The A50FBLCSC2 2-meter (6.6ft), 10 Gigabit, Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable is terminated with one LC (male) connector and one SC (male) connector and is composed of 50/125 micron OM3 aqua fiber to deliver reliable data transfers at blinding speeds making it perfect for fiber cable runs between multiple backbone switches, hubs and routers as well as higher end networking equipment.
Suited for a broad range of environments, A50FBLCSC2 is housed in a flame retardant, LSZH (Low-Smoke, Zero-Halogen) cable jacket, taking safety to a new level by ensuring minimal smoke, toxicity and corrosion in the event of a fire - making it the best choice for a wide range of environments, including industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Efficient data transmission
This fiber optic patch cable utilizes a multimode duplex design, providing efficient data transmission capabilities suitable for high-bandwidth applications. -
Versatile connectivity options
Equipped with LC and SC multi-mode connectors, this cable supports various connectivity needs, allowing flexibility depending on the network setup. -
Safe indoor usage
Constructed from Low Smoke Zero Halogen materials, this cable minimizes hazardous emissions when exposed to fire, promoting safety in enclosed spaces. -
Environmentally compliant
The cable meets RoHS standards, ensuring that its materials and manufacturing processes do not harm the environment, aligning with sustainable practices.
- StarTech.com 2m Fiber Optic Cable - 10 Gb Aqua - Multimode Duplex 50/125 - LSZH - LC/SC - OM3 - LC to SC Fiber Patch Cable (A50FBLCSC2) - patch cable - 2 m - aqua
- Patch cable
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 2 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- 2 x SC multi-mode - male
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Patch cable
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 50 / 125 micron
- Length
- 2 m
- Aqua
- Connector
- RoHS
StarTech.com OM3 Multimode Fiber Cable | In Stock | £14.56 |
