StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - SC
Quicklinx: 7Y1TWS00 Mfr#: A50FBLCSC2
Length: 2m
Colour: Aqua
10 In Stock
£16.55 ex VAT
£19.86 inc VAT
Deliver fast, reliable, data transfers, safely, over high end networking equipment. The A50FBLCSC2 2-meter (6.6ft), 10 Gigabit, Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable is terminated with one LC (male) connector and one SC (male) connector and is composed of 50/125 micron OM3 aqua fiber to deliver reliable data transfers at blinding speeds making it perfect for fiber cable runs between multiple backbone switches, hubs and routers as well as higher end networking equipment.
Suited for a broad range of environments, A50FBLCSC2 is housed in a flame retardant, LSZH (Low-Smoke, Zero-Halogen) cable jacket, taking safety to a new level by ensuring minimal smoke, toxicity and corrosion in the event of a fire - making it the best choice for a wide range of environments, including industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
  • Efficient data transmission
    This fiber optic patch cable utilizes a multimode duplex design, providing efficient data transmission capabilities suitable for high-bandwidth applications.
  • Versatile connectivity options
    Equipped with LC and SC multi-mode connectors, this cable supports various connectivity needs, allowing flexibility depending on the network setup.
  • Safe indoor usage
    Constructed from Low Smoke Zero Halogen materials, this cable minimizes hazardous emissions when exposed to fire, promoting safety in enclosed spaces.
  • Environmentally compliant
    The cable meets RoHS standards, ensuring that its materials and manufacturing processes do not harm the environment, aligning with sustainable practices.
StarTech.com 2m Fiber Optic Cable - 10 Gb Aqua - Multimode Duplex 50/125 - LSZH - LC/SC - OM3 - LC to SC Fiber Patch Cable (A50FBLCSC2) - patch cable - 2 m - aqua
Patch cable
Duplex fibre optic
Type of Fibre Optics
Multimode
Length
2 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
2 x SC multi-mode - male
Aqua
Network Cable Type
Patch cable
Duplex fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
50 / 125 micron
Length
2 m
Aqua
Connector
RoHS
7Y1T StarTech.com OM3 Multimode Fiber Cable In Stock £14.24
Length: 2m
Colour: Aqua
