Charge and Sync your Apple Lightning-equipped devices over longer distances. The USBLT2MB 2m Black Lightning to USB Cable for iPhone, iPod, and iPad provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
This longer Lightning USB cable offers 2-meters in cable length to overcome distance restrictions while still providing full charging power. Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 2m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
- StarTech.com 2m (6ft) Long Black Apple® 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable (USBLT2MB) - Lightning cable - Lightning / USB - 2 m
- Cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 22/28
- Length
- 2 m
- Black
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Sync and charge
- 2-year warranty
- Designed For
- P/N: ST4200MINI2, ST4200MINIC
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Technology
- Double shielded
- 22/28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 2 m
- Plated Connector
- Nickel
- Sync and charge
- Black
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- RoHS
- Limited warranty - 2 years
- Designed For
|  | StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £15.00 |
|  | StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £13.66 |
|  | StarTech.com 2m (6ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £15.20 |
