StarTech.com 2m (6ft) Angled Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad
Quicklinx: 97RCWS00 Mfr#: USBLT2MBR
Colours:
Charge or Sync your iPhone, iPod, or iPad over longer distances, keeping the cable out of the way. The USBLT2MBR 2m Angled Lightning to USB Cable for iPhone, iPod, and iPad is colored to suit black mobile devices and provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
The angled Lightning connector positions the cable in such a way that it allows for easy access to your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
The longer USB to iPhone cable design offers 2-meters in cable length to overcome distance restrictions while still providing full charging power.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 2m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 2m 6ft Angled Black Apple 8-pin Lightning to USB Cable for iPhone iPod iPad - Angled Lightning Cable - Charge & Sync - 2 m (USBLT2MBR) - Lightning cable - Lightning / USB - 2 m
Cable
Double shielded
American Wire Gauge (AWG)
22/28
Length
2 m
Connector
Lightning - male
Connector (Second End)
USB - male
Angled connector
P/N: ARMTBLTIW, SECTBLTDT, SECTBLTPOS, STNDTBLT1A5T, STNDTBLT1FS, STNDTBLTMOB
Cable Type
Lightning cable angled connector
Interface Supported
Lightning / USB
Double shielded
22/28
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Nickel
Sync and charge
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
97RC StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £101.41
97RC StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £38.96
97RC StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.23
97RC StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £15.14
97RC StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £13.56
97RC StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £26.14
97RC StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
97RC StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £14.86
97RC StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
97RC StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £108.59
97RC StarTech.com 2x USB Wall Charger 17W / 3.4A In Stock £14.91
97RC StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £128.27
97RC StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £64.21
97RC StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £44.32
97RC StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £56.18
97RC StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £12.51
97RC StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £39.49
97RC StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £31.05
