StarTech.com 2m / 6.6ft Angled Lightning to USB Cable - Black
Quicklinx: FGG3WS00 Mfr#: RUSBLTMM2MBR
Length: 2m
£14.44 ex VAT
£17.32 inc VAT
This angled Lightning to USB cable withstands the demands of charging and syncing your mobile devices. The angled Lightning connector gives you easy access to your mobile device, even while charging. And, and the longer cable is ideal for overcoming distance restrictions.
With Kevlar aramid fiber reinforcement, the durable Lightning cable is sheltered from the stress of frequent bends and twists, which allows the cable to flex without over-stretching.
Cable Key Features. Aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil and braided shielding. TPE (thermoplastic elastomer) cable jacket is softer and more flexible than a standard PVC cable.
Constructed to prevent the connector from separating from the cable jacket, the extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle.
Connector Key Features. Lightning connector provides 12W for charging your iOS devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180-degree angle.
  • Built for daily use
    With aramid fiber reinforcement, the durable Lightning cable is sheltered from the stress of frequent bends and twists, which allows the cable to flex without over-stretching.
  • Right-angled connector
    90 degree connector eliminates tension and protects the Lightning port of a device. Ideal for car mounts, classroom desk mounts or mounted POS.
  • Apple MFi-certified
    Fast and reliable charge from USB-A charger/port to Lightning devices.
StarTech.com 6ft (2m) Durable USB A to Lightning Cable, Black 90° Right Angled Heavy Duty Rugged Aramid Fiber USB Type A to Lightning Charging/Sync Cord, Apple MFi Certified, iPhone 12 Pro - iPhone 7/8/11/11 Pro - Lightning cable - Lightning / USB - 2 m
Cable
Double shielded
Length
2 m
Connector
Lightning - male - angled
Connector (Second End)
USB - male
Sync and charge, strain relief
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
2 m
Connector
Apple Lightning - male - angled
4 pin USB Type A - male
MFI, EMI
FGG3 StarTech.com 1m / 3.3ft Angled Lightning to USB Cable In Stock £14.34
FGG3 StarTech.com 1m / 3.3ft Angled Lightning to USB Cable - White In Stock £12.00
FGG3 StarTech.com 2m / 6.6ft Angled Lightning to USB Cable -White In Stock £15.04
Length: 2m
